Bluetooth speaker SRS-XB13 extra bass
Dangee
Hello. I am interested in Bluetooth speaker SRS-XB13 extra bass. Is there a possibility to play music from USB type C input using USB C to regular USB adapter? Or is this USB type C input just for charging the speaker? Thank you.
1 REPLY 1
Elodin
Moderator
Hey, the (USB Type-C) is a DC IN 5V port that's only used for charging the speaker. You won't be able to playback music from this port. I hope this helps.
