connect SRS XB-3 with SRS XB-31
timh5599
Trying to connect the Sony srs xb3 with the srs xb31. Is this even possible? By just trying with the 'add' button does not work. Anybody got an idea if it is even possible? The xb3 does nog have wpc, so that isn't an option. Thanks in advance.
1 REPLY 1
Sean_Mc
Moderator
Hi Tim,
Welcome to the Sony community.
My understanding is that you would need the Wireless Party Chain (WPC) found on the XB31 for pairing speakers.  It would be possible however to connect two XB3 Speakers via Bluetooth. You can see more details on this here.
Best wishes,
Sean Mc
