Freezing
Eddiezzz
Freezing
Music centre constantly freezing and not transferring anything
2 REPLIES 2
Pascale_F
Moderator
Hi Eddie,
Welcome to the community.
I'm just going to try to find some answers for you. In the meantime, maybe someone else in the community might have some ideas.
Thanks,
Pascale
batee5
Specialist
Hi Eddiezzz,
Welcome to our community!
You can always start with the basics to try to resolve this issue. Make sure your computer matches the program's system requirements which are listed on this link. Also, make sure you're using the latest version which is Version: 2.0.2.
You can also try to uninstall the program then install it again.
Let us know if any of the above helped and if not could you let us know more details with screenshots if possible?
Cheers,
Batee5
