MDR 1000X stopped charging
alessio.macri
Hi there,
I own a pair of MDR1000X. Everything always worked fine until yesterdat when they suddenly stopped recharging. I tried to plug them while they were running low with different cables and usb plugs but nothing seemed to work. They just won't charge anymore. I was wondering if there is anything I could try to solve this. They've been quite an expensive purchase so I would like to get them fixed.
Thanks!
4 REPLIES 4
IamNic
Hello @alessio.macri,
have you tried to reset the headset?
Here you can read how a reset is performed:
https://helpguide.sony.net/mdr/1000x/v1/en/contents/TP0001176174.html
https://helpguide.sony.net/mdr/1000x/v1/en/contents/TP0001176175.html
- Nic
alessio.macri
Hi Nic,
Thanks for your respnse (sorry for the late reply, I had login issues).
I did both, now they are factory-reset, but still not charging 😞
Sonyvores
Contributor
How long have you been using it?
if it doesn't charge, does it work while plugged?
IamNic
Then it is probably best to get in contact with the service.
- Nic
