WH1000 mx5 shuts down randomly with high pitched noise
PT1337
Hi all,
As written in the description my headphones shut down randomly, it happens inside and outside with no time pattern.
When thy switch off they give off a short high pitched noise which is very uncomfortable.
Does someone experience the same?
2 REPLIES 2
TheGOAT
@PT1337 Have you tried to initialize the headset? It's very useful in these cases as it puts the headphone back to the factory mode: https://helpguide.sony.net/mdr/wh1000xm5/v1/en/contents/TP1000541013.html
PT1337
Thank you for the reply and the suggested solution.
I now reseted the headphones and will report if it helped!
Cheers
