Charger sony uch12
Angelcid
Charger sony uch12
I have and charger sony ach12 but I swell the battery of my lg v20 nose if the phone was the one that failed or it was not compatible now buy the sony xperia xA2 ultra and I would like to know if it can not damage my sony or the charger maybe it does not work or do your work
1 REPLY 1
HRJ86
Charger is a charge regardless of which one you choose to use on it (probably will get flack on this). I use Anker Quick Charge 3.0 since the phone is designed for that feature so I would recommend going in finding one that has a function.
