My mobile screen have been flickering from few days, While when i will get the call or when i open the phone its screen wont work suddenly.. I need to switch off the screen n again On using power button then then it will work.
Means it will stop screen touch. And some it has been automatically do the operations on phone means display worked automatically, most of time its click at right side but without touch. Please let know the solution as soon as possible else replace me this mobile.
I hope Sony brand will takecare of their trusted customers always n forever.
Thanks
Vinayak
Ho problemi su xa2 ultra si spegne display come se premessi il pulsante di accezione oppure passa alla schermata principale che poi devo tirare su da menu a tendina.
I have problems on xa2 ultra turns off the display as if I pressed the accept button or go to the main screen which then I have to pull up from the drop-down menu.
gt
