LCD Screen Problem
Agenor1
LCD Screen Problem
Hello, for some time the screen of my phone makes streaks (see photo below). I specify that the screen did not take any shock, I tried a restart, a re-factory value and then a restoration of the XPERIA software without any result. So I would like to know if the bug has already happened, and if so, the possible solutions to solve it.
Thank you for your future answers.
Exemple homepageExemple homepageExemple play storeExemple play store
3 REPLIES 3
Leila777
Hi my sons phone has the same issue, I took it into a three store and they tried to tel me it had got wet which I know hasn't happened. Have you had any info yet?
Johnny_Curry1
Did you repair the software using Xperia Companion? I'd do that over a factory reset via the settings.
If that doesn't fix it then it mostly likely is a hardware error, either from damage (e.g. drop) or if it is a fault with the device then you'd be better of contacting your local Sony mobile support for a repair under warranty.
I have had my XA for about a month and it has no issues.
angelmiller
Better You Contact You Seller.I hope you have Warranty still ...
