Pattern problem - Xperia Xa
PanebFlub
Hello,
I have an issue with my Adnroid Xperia XA from my job since this morning.
I left it on a desk all the week-end, so it ended without battery. I plugged it when I arrived, and the battery being loaded showed on the screen.
Once it has booted, I tried to use my pattern to unlock it.
Surprise: it isn't recognize anymore...
I'm 100% certain I am using the right one, I wrote it down on my old phone in order to being able to verify it.
Is it a known bug?
Any idea how solve this?
I've already tried to restart it several times, without success.
At one point, a strange message was ""To unlock your phone, shut it down and restart it". Though it doesn't help.
Should I try something else? Let him go to 0% once again?
Thank you in advance for your help (and sorry for english mistakes, french speaker here :p)
1 REPLY 1
Christofer
Champion
Hi @PanebFlub, I'm sorry to hear this. Slightly_frowning_Face
If you are unable to unlock the device using your set pattern I recommend that you perform a software repair using Xperia Companion. This will allows you to perform a full reset of the device without having to unlock it first.
I hope this helps!
