Xa ulta browsing problem and sim signal
Yara3
Hii.
Please my xperia xa ultra phone can't open any site from any type of browser app.
It opens all kind of internet apps youtube fb whatsapp.. Etc but doesn't open sites from chrome opera firefox etc. It keeps saying internet error on wifi or in data
Can u help me?
I have another problem that my 2 sim car signals that appear above comes empty suddenly and the data stops and i lose signal for 20 secs then it comes back and it repeats alot.
Thanks in advance Slightly_smiling_Face
2 REPLIES 2
profile.country.PH.title
MarlonUk1
hello.
 try to configure your APKs, you can have this settings by contacting your local network provider.
your network provider might need you to change Apk for every different activity.
about the sim signals, remember:
Your device supports the use of two different networks at the same time. You can select from the following network mode combinations when two SIM cards are inserted in your device:
  • One LTE network and one GSM network
  • One WCDMA network and one GSM network
  • Two GSM networks
For each SIM card, you can set your device to switch automatically between mobile networks depending on which mobile networks are available where you are. You can also manually set your device to use a particular mobile network mode for each SIM card, for example, WCDMA or GSM.
also try to read some more information regarding mobile internet on  your device: http://support.sonymobile.com/global-en/xperiaxaultradual/userguide/Browsing-the-web/
Jake-SonyXperia
Champion
Hi @Yara3,
Welcome to the community,
Sorry to hear about the issues you have had Slightly_frowning_Face
With the browser based issue and the error you are presented with, I suggest checking the following location.
Apps > Settings > Date & Time > Make sure the date is correct and not set very far behind if possible try selecting automatic Date & Time
I understand this may sound bizarre, however if the Date is set to far behind you are unable to use Google's browser and are presented with the error message as mentioned, although I am not sure about the other browsers.
Let us know how you get on.
