I am using Xperia XA Ultra for the past 6 months but for the past few days, I am experiencing a unique problem while charging this phone.
First, the speed of charging slows down after crossing 70% and it takes usually around 1 hour from 75% to 95%. Earlier, it never happened like this.
Second, when I plug in the charger, the charging alternates every few seconds. For instance, the phone will be charged for 8-10 secs and then get disconnected (on its own) for 1-2 seconds and then again starts getting charged automatically. This process repeats for 5-7 mins and then charging becomes stable.
Not sure if this is being caused by some update/bug. Request your help to resolve this issue.
Thanks Cameron for your prompt help.
As you suggested, I will check charging using another USB cable now and also check it in safe mode. Will revert with my findings. Thanks for your help.
