Hello, I have a regular Sony Xperia XA1, not the ultra. It has had a massive battery drain these past few days, it will go from 100% to 0 in minutes or not charge at all when phone is powerd off even tho it says it is charging, it will only charge while powered on and die fast once its disconected.
I want to replace the battery, but the only problem is this seems to be the most elusive battery to find on the planet or at least on the US side. My question is will the regular more in abundance Sony XA battery work for the XA1, seeing as they seem to be the same, both are 2300mAh 8.8 wh 3.8v 4.35v
Thank's.
