I have a 64GB SD card in my XA2.
I plug in an OTG cable with a simple card reader and a 32GB card inside.
In the list in settings->storage I can see the 2 SD cards available and also the capacity is correct.
But either I try to browse the 64 or the 32 GB SD card, It allways shows the content of the 32GB (the one connected via OTG). I have tried many file browsers, and all of them shows only 1 sd card available, the one connected via OTG. This way I am unable to copy files from the external to the internal SD.
The worst part is the ejecting. Either I eject it in settings as it souoused to be or not, after removing the OTG SD card, the phone says the internal SD is inside but shows it is empty. Sometimes even the settings application crashes whyle trying to open the SD card. All file browsers say the card is empty or that it cannot be opened. I have to restart my phone to make the internal SD visible and to function again.
Please fix this huge huge bug.
Note: This only occures when the external drive is an SD card. It works as it should with HDD or USB strick drives.
