Deel jouw ervaring!
Opgelost! Ga naar oplossing.
Settings > apps > camera > storage > clear data > restart the phone > check again
no, only the settings on your camera but won't affect the pictures
Excellent
I have the same problem
so i DId what u suggested , and it was okk then ,
but when i changed a few settings of my camera app according to my use the problem remains same NO ZOOMING
so do u have any solution about it
what did you changed ?
mainly resultion 9mp to 13mp back and 5mp to 8mp front, that's it
and then the zooming vanished ..
could you repeat the steps to clear the camera app data > boot in safe mode and try to recreate the issue.
Actually I checked again with every changes and it is working
however it seems that zoom is only working with FLASH ON
but if i use the flash off the zoom feature disables automatically
