I have same issue, but have found, before you recharge your phone go to battewry care and switch off and then back on again and it works ok.
If your phone is rooted and with Xposed, then you can install BatteryCare+ to troubleshoot.
https://forum.xda-developers.com/xperia-xz/themes/app-batterycare-t3547695
@trashcan wrote:
I agree with Having Troubles.. Had experience the non working status of battery care.. Upon switching it off, then switching it on prior to recharging makes it work...
Only problem is, you have to switch it on and off every time you go to recharge or it wont work ,and your phone will be charged in about 2 or 3 hours
Battery care still not working
