- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Double tap to wake not working properly
With the Sony launcher double tap to sleep works fine so I don't think this is a hardware issue.
I tested this with the stock Sony launcher and Nova enabled and both have the same issue.
This isn't my phone obviously, but this is similar to how my phone is behaving: https://www.youtube.com/watch?v=iukYtlqDww4
I tried it with the phone in my hand, and also laying flat on a table.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I'm in UK and called my xperia support and they mentioned if pc companion repair doesn't fix it then it's hardware issue. (I have already repaired once)
But when I mentioned if it's a hardware issue how come double tap to sleep works perfect and screen responds perfect when on they couldn't give me answer.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Sony needs to build a culture of people who care in their support department. That's one of the biggest weaknesses of the Xperia line - inept support people who don't care, no single global coverage to deal with (Sony US told me I have to contact Sony UK), and horrible turnaround times.
How can management continue ignoring these issues and hope to grow their mobile unit?
I dread dealing with Sony's support department and never felt that way when owning a Google, Samsung or Apple device. it's a shame too because the phones are really great.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I'm very sorry to hear that
I've been testing this here but i've been unable to replicate this on my phone so far. Would it be possible for you to take a log from your phone after you have tried to use tap to wake without success and send that to me in a private message?
To do this:
Settings > About phone > Build number, tap 7 times on the build number
Go back to Settings and select Developer options and turn on "USB debugging". Then tap "Logger buffer sizes" and set this to "4 M".
- Turn off display and then try to double tap to wake. In case it doesn't work, turn on display by on/off button and then:
Settings > Developer options, select "Take bug report". When the report is ready (may take a minute or so) you get a notification that you can tap and share to Google Drive. Please send me a link to this file in a private message.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I have the exact same problem! I even did a factory reset.
Stamina Mode is off all the time.
I have to press the screen multiple times and hope that the screen lits up somehow.
I heard that someone had it fixed after switching for a new device with the same software Build number.
Also saw some people having the same problem on XDA.
So is it a hardware issue or software?
If it's a hardware issue, I will need to bring the phone back to the store as i just got it few days ago.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I have just sent Rickard a log following his mentioned instructions. It would be great if others can do the same so that it will hopefully help the root cause to be identified easier ☺️
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
When screen goes off by itself, maybe it goes into a deeper sleep making it less responsive?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
