Battery suddenly drops from 60% to zero
Curlymike
Посетитель
The battery suddenly drops from 60% to zero. Has been doing this for a month. Seems to recharge very very quickly afterwards. Indicates software or power management issue. Help... Can't live with 40%...
Теги (1)
15 ОТВЕТ 15
Amit7830
Посетитель
yes may be you are true..facing same experience
RA74
Посетитель
HtooMyatThu
Посетитель
I've the same issue to my Xperia Z Ultra after upgrading to 5.1.1
I don't know what happened and is it hardware or software issue ?
Do I need to change battery ? or what should I do.
I love that device.
Please help me advise and thank you.
Curlymike
Посетитель
I bought and installed a new battery and it solved the problem.
rajendrabhai
Посетитель
But this is happening with my new BM41 battery installed 2 days back
parshan
Посетитель
iwasplaying a game , at 44% battery , I see could see my battery percentage in game , it was 44% ,I came out of game , then Isee i had 44% battery , I get back to game and in middle of game it shut down , then i turn it on and I see it was 0% battery , I go to my battery details , Ther's a batter chart in setting , it goes from 44 to 0 in a straight line , it means that it gets 44 to 0 in a second without a reason , i'm using samsung tab e , android 4.4.4 kit kat and 5000mAh battery ,  I bought this tablet for 6-7 month ! and not a year ! please help me why , and if there's a problem tell me how to fix it
