Hi Guys, I have just updated my Z1 to 4.3 firmware yesterday, BUT faced a problem at installing Info-eye 1.2.04 through update center , after it finishes downloading it says ( Info-eye could not be installed) , I've tried multiple times but no use....SO please help me withthis problem it's driving me crazy as I regret updating the software now
Same problem with my device!
sending a pm.
I re-installed the update.it solved.
Try updating ur phone using SUS, it may fix the problem.
Even when you restart the mobile the update would be disappeared and the info-eye would be as it has been removed from the mobile could you help us in this problem?????!!!!!!
@Ibrahimabdo wrote:Even when you restart the mobile the update would be disappeared and the info-eye would be as it has been removed from the mobile could you help us in this problem?????!!!!!!
You might want to check in the Settings -> Apps and swipe to the right for ALL apps. Then scroll to the very bottom.
Info-eye might be disabled and disabled apps are at the bottom of the list.
Sometimes that happens after a failed upgrade installation for preinstalled apps.
