Is the xperia z camera in LOW light is better then Xperia p (low light ) ..? heard many poor reviews about xperia Z camera in LOW light ..! Was using xperia p ,have decided to go for xperia Z . Help me out guyz.
do you have an issue? low light its great, it's better if you have HDR on, also if you have normal settings and play with metering, ISO, etc for best results or superior auto will be ok too.
Don't forget to mark the Correct Answers & Helpful Answers
See that link:
Photo Quality Comparison
http://www.gsmarena.com/piccmp.php3?idType=3&idPhone1=5204&idPhone2=4436
Thanks guyz..
anytime
