Hi all,
I have the problem that my notification LED is not working at all.
Stamina mode is not on, the phone has been rebooted, i tried a factory reset.
Gmail, missed calls, Whatsapp i dont see any notification led only wenn charging.
Any1 a tip for me what todo?
Thanks
Dennis
WARNING!!! DO NOT CHANGE COLORS IN Whats app.. the notification problem will again occur. i dont have any notifications since i changed the group notifications to purple in whatsapp.
No mcafee here on the VF NL phone i checked everything also tried SEUS to restore all nothing seems to help this bug even light flow not.. Sony indeed needs to fix this asap this is a major annoying bug for users at work i cannot put the sound on so it would be nice to know if some one whatsapped you or any missed calls... this is just rediculous...
it is and if u try to call the xperia support or send tham a mail u ll see that they have no idea what a smartphone is, i ve got as an answer " try to download a 3rd part app from the store"...afther spenr 699 euros i have to wast time to find out a solution????
And the display colors??? do we want to talk about that to?? washed and uninspiring, the black is grey...or maybe i m going blind
yes it change eventually got it to work when I get new gmail the light starts blinking green
call the sony helpdesk if you haven t done so and confront them. of course in the hope you get a bit of a seasoned tech specialist.....
i got another problem after a full charge my stand by time shows only 23 hrs... i don t know if the gauge is incorrect or the battery is faulty
this is what you get with high-end smartphones though the complexity causes more glitches. And this is Sony's first flagship model in the smartphone world they are way behind on the curve when it comes to Apple and Samsung who eliminated all child diseases over longer period of time
what did ya do to make it work?
if sony can or cannot build a proper smarthphone is not my problem, but as we are the customers and as we spend a lot of money for a gadget like that we are xpecting that things works right..
for such a price what have we got??
I full hd display with washed colors
An average 13 megapixel camera, not better than a 8 megapixel
Battery drains , no reasons why it drains so fast
Notification light isn t working , maybe sometime yes, maybe only on a few devices
No MKV codec
Most of the videos cannot be playd on that phone not even stremed on a big screen
Avarege audio
Poor wifi connections
Phone gets dirty and glossy after 3 minutes...
i guess the list is tooo long by now...even worst than LG
first it was working only when the phone was charging but not when it was without power input. does it work for you when it is charging? thats one thing you should check because it isn t i get replaced again
I updated to latest sofwtare hadnt done that yet and then closed the stanima mode. i am checking to see now if missed calls work they should be a blue light blinking then
yes but some of the previews did argue that the 13 mill camera wasn t really that much better then the samsung 2 camera plus camera pic quality is so much based on individual user taste
also comments were made way before release about the viewing angles which are poor plus glossy screen is a huge factor in a lot of touch screen phones
I do agree about the lack of MKV codec support and the battery drain a and/or sluggish battery probe/gauge
as far as the screen goes I get used to that if i watch full hd videos i think it is mind blowing
but a sony phone can be a risk I had the xperia T which was a battery nightmare the battery just went dead on 50% showing
there is no latest software version, i m running on android 4.1.2 version 10.1.A.1.350
i m sick of trying...i ll bring it back
thats the version i am running 4.1.2. of course it is weekend and the phone is just released but i sincerely hope some sony adinistrators are going to run through this forum so far they have been missing in action
these FORUM administrators usually know more then the sheep in the call centres the latter group perhaps did one training and read the manual thats it
wait for the HTC one thats got full HD and some serious specs or the S3.....
i m still using my galaxy note 2 .....i though sony would really manage to build a good phone this time...but this is the worst ever
