Hello all,
I use Darktable (now version 4.2.2) to convert and enhance my .raw files from my ILCE-7, ILCE-5100 and now my new camera the ILCE-6700.
But after importing my 6700 files when opening a file in Darktable I get a error message that Darktable cannot read the whitebalance data in the EXIFdata of the 6700 raw file. Is this known in the coomunity? At the moment I have a work around by first converting .raw to .tiff and then editting, but then I loose a part of the camera and lens EXIF data.
Has the W/B part of the EXIF data changed to the way written in the .raw files of the 7 or 5100.
Regards,
Dirk W. Rotgans
Even snel op de website van Darktable gekeken en de a6700 staat (nog) niet bij de lijst van ondersteunde camera's. Het is denk ik even wachten tot deze software de camera ondersteund.
Succes!
Antonette
Succes!
Antonette
