A7rIV no PC connection available in USB connection menu
SOLVED
J.Herschel2
Hello,
I am trying to tether my A7rIV using the Edge capture software. I understand that I am supposed to go to the USB connection menu and select PC  Remote. However, this option is not available. I only see Auto / Mass Storage / MTP. I've update the firmware to 1.1 and even resetted all settings. I've seen video tutorial and they all had the fourth option PC Remote. Can somebody help me figure this out? Thanks, John
1 ACCEPTED SOLUTION
Accepted Solutions
Marino.Manolo
2 REPLIES 2
Marino.Manolo
J.Herschel2
Thank you for your response Marino! I didn't realise the menu was moved over to network with the mark IV. I also had issues tethering but found the solution.
