Im going to Dubai and i am planning to buy a Nex-3 camera.
Its a little cheaper than i Denmark (DK is so expensive).
Do you know: If i buy a Sony product, do i then get "World Wide Warranty" on.
It means that even if i am i Denmark, could i then send it in to Sony if its broken?
Best Regards
Hi OzZi1310,
welcome to Questions & Answers..:smileyhappy:
OK as far as I am aware products purchased within Europe would be covered in another EU country. As your planning to purchase in Dubai, different regions having different laws to the EU & all that, I would expect that you would get your product repaired as long as it's still within the manufacturer’s warranty period.
Hope this helps..
And i want to be SURE! :smileygrin:
Hi OzZi1310,
Hope this helps..
