Partagez votre expérience!
Hello,
My WiFi password is only 3 characters long,but when i enter the password on my Xperia E the " connect " button is greyed out.It seems that the minimum amount of characters is 8. Is there a way to remove this limit without changing the password on my router?
Résolu ! Accéder à la solution.
As far as I know you need to have 8 characters in the password unfortunately.
Oh, ok. Then i'll just have to change the password on my router. But Thanks anyways
