Hi folks,
We already have two fine bluetooth connectable Sony speakers, why can we not use these instead of having to buy new Sony speakers?!?
Has anybody found a way around this situation?
Thanks for your suggestions!
@ThijsvanLeer wrote:Hi folks,
Hi @ThijsvanLeer Assuming that you have the HT-ZF9 the SA-Z9Rs connect by using 5GHz WiFi and not Bluetooth and are fully integrated into the soundbar firmware. I have this setup and can only say that the quality is stunning.
Da.... too bad, that leaves me with two good speakers with no use and two new ones to buy.
Perhaps one day the AV industry will also become a sustainable industry....
Anyhow SonyUser30Yrs, Thanks for your fast response!
