Bravia PING sound
SOLVED
profile.country.en_GB.title
Blue-Flame
Bravia PING sound
I have a Sony Bravia KDL 32EX523 Television
What is driving me mad is the PING sound that it makes when you switch on or change in-puts etc.
Can any one tell me how to stop it, I have been through the manual, I cannot find anything about it
Thanks
Blue-Flame
1 ACCEPTED SOLUTION
Accepted Solutions
Thalamus.
Champion
Thanks
Blue-Flame
Hi Blue-Flame,
welcome to Questions & Answers..:smileyhappy:
Depending on which sound from your 32EX523 is driving you mad try this..
Go to the Home menu..
Then browse to Settings..
Followed by Sound..
In the Sound menu click on Key Tone..
Select “Off” to turn the sound off..
or
In the Sound menu click on Start up Sound..
Hopefully you should now get some peace and quite..
5 REPLIES 5
Bravia55HX
not sure for your model, try settings- sound- key tone, set to off
Thalamus.
Champion
Thanks
Blue-Flame
Hi Blue-Flame,
Followed by Sound..
or
Bravia55HX
Hi Thalamus,
since i posted the correct answer some 6 hours before you did, give yourself a gold star for jumping the queue!!
Blue-Flame
Thank you Thalamus and every body else who came back to me thanks for all your help
Thalamus.
Champion
You're welcome Blue-Flame..:smileyhappy:
