Need help with Roxio
SOLVED
profile.country.en_GB.title
kamkasha
I need to have rcpcore.msi file in order that the Roxio inside my computer works.
When I bought my vio it was working fine. Today I tried to copy my folders to a disc. Then a notice came up saying it needs rcpcore.msi in order the program Roxio works. I wonder how can I get this file?
I have Roxio Easy Media Creator 10LJ.
Many thanks
Tags (1)
1 ACCEPTED SOLUTION
Accepted Solutions
Thalamus.
Champion
Hi kamkasha,
welcome to Questions & Answers..
Not sure what model you have but you may be able to re-install Roxio using the Vaio Recovery utility..
The guide below may help but if not let us know your model hopefully we can give you a more accurate guide..
1 Launch VAIO Recovery Center
2 Select Reinstall Programs or Drivers and click Start.
3 Read the information about software or features to resolve the problems,
select Skip if you have already tried all of them, and click Next.
4 Click Next.
5 Select the desired software or software driver check box and click Next.
6 Follow the on-screen instructions.
1 REPLY 1
Thalamus.
Champion
Hi kamkasha,
4 Click Next.
