After formatting my Vaio VPCF11M1, and installing the professional version og windows 7, the smart network application doesn't work. See the picture for more details.
Anyone knows what to do ??
Hi RoanJaan,
This problem has been raised a couple of times before and the solution suggested was to ensure that all of the original drivers and Sony utilities are installed prior to installing Vaio Smart Network as there may be dependences.
Unfortunately neither of the OP's bothered to reply so whether this is the solution is not known...
Rich
Hi RoanJaan,
Rich
I actually formatted the PC becouse of all the software.
I didn't need them, and they bothered me a lot.
So to install all of it again, will be same as shooting myself in the foot.
I guess I have to live with it not working.
It’s not the software that may need to be installed to get Smart Network working, just the Sony utilities that control the functions of your notebook – most of the bundled software is not available for download anyway.
Rich
Well..
After installing SFEP driver, Setting utilities, sony shared library, now it works...
Tnx
This Thing Works Even After Installing SFEP and Sony Shared Library.
