Compatibility CMT-LX50WMR
SOLVED
profile.country.en_GB.title
grkirby55
     Does anyone know which Walman devices are compatible with the dock on the CMT-LX50WMR? In particular I wish to know if a NWZ-A818 will be snug fit and attach directly to the WM port.
1 ACCEPTED SOLUTION
Accepted Solutions
crsheph73
from the manual:
Type A attachment
Compatible “WALKMAN” models:
NW-S600 series, NW-S700F series,
NW-A800 series, NWZ-A810 series,
NWZ-A820 series, NWZ-A820K series,
NWZ-A720 series, NWZ-S730 series,
NWZ-S630 series, NWZ-E430 series
Type B attachment
NWZ-S510 series, NWZ-S610F series,
NWZ-X1000 series
Install the compatible oval
attachment for “WALKMAN.”
Match the hole inside the
WM‑PORT with the projection
on the left side of the
attachment.
Continued 
1 REPLY 1
crsheph73
from the manual:
Type A attachment
Type B attachment
NWZ-X1000 series
attachment.
Continued 
