Just got a new Sony Xperia XA but having big issues with connecting onto the WiFi in work. I can get connected intermittantly but more often than not it just fails with authentication issues (all passwords etc are correct as it does connect maybe 1 time out of 20) . I've tried in safe mode as suggested on other posts. The WiFi at home seems fine no issues there. If I cant get a solution to this then it's going back to Virgin Mobile. Running Android 6.0.1 & build number 33.2.a.3.81 kernel version 3.18.22+ .
Anyone got any ideas?????
Hi @johnnybedo,
Welcome to the community,
Sorry to hear about the Wifi issues, based on what you have advised so far, the issue seems to stem from the work Wifi and nothing else, with that in mind, you may be best to speak with your IT department.
Let us know how you get on.
The WiFi in work is fine for Nokia, HTC iPhone just the sony XA having issues.
The router is in fact wireless AP's throughout the large work environment (NHS location) so no single real router as such, just access via our service provider - Virgin Media.
In the end decided the phone wasn't for me although a nice enough phone esthetically, with issues like this i'd end up spending most of my time sorting those out. Decided to return the phone & look for somthing more robust & able.
BTW I work in the IT dept. as a tech so I know when the issue lies with a device or the WiFi system.
thanks anyway
Sorry to hear that, all the best for the future.
I just migrate from Xperia Z3+ to XA1 Ultra and having the same problem. Wifi connection either not available or connected but no internet access. The only way I can by pass this is to manually reset the bluetooth, turn it off then on.
The Z3+, in the exactly same environment, does not have the wifi/bluetooth compatibility issue.
I'm getting the same issue regardless where and what wifi network I connect to. Sony, fix this issue! WiFi only works if Bluetooth is off. This is complete garbage. Regretting this phone, and will never buy another Sony phone if this persists.
