Battery notification light status
| Green | The battery is charging and the battery charge level is greater than 90% |
| Orange | The battery is charging and the battery charge level is less than 90% |
| Red | The battery is charging and the battery charge level is less than 15% |
http://support.sonymobile.com/global-en/xperiaxa1/userguide/charging-your-device
Thank you for that information @WirelessWonkFL
@1997Vivi, see you have a lot of questions about your new phone which is great! I recommend you check out the userguide. You can see it both where @WirelessWonkFL linked, and directly from your phone too under Settings > Support > Web Support.
And of course if you have any more questions, please feel free to ask :smileysmileythumbsup:
