XA2 ultra fingerprint issue...
SOLVED
profile.country.RO.title
AlexandruRai
Contributor
I bougth for a friend the XA2 ultra device. I did an upgrade. Then setting fingerprint sensor I've notived that it reacts when touching but it always brings me to the pattern/pin window without unlocking. It does like a secondary power button bringing me to the pattern. Is that normal, it's that a software issue? Please help!
1 ACCEPTED SOLUTION
Accepted Solutions
AlexandruRai
Contributor
I found the issue. There is a bug in the system that does not allow to skip the pattern/pin/password if the phone is locked by a third party admin usage application, like a proximity sensor app or on/off button app. It seems that closing only by auto sleep screen (15 sec to 30 min) in display settings or power button, let fingerprint skip the pattern/pin/password, recognising my print.
Admins, please send this issue to Sony for next upgrades to be solved. Fingerprint should be active no matter how I lock the screen - by app or by power button.
Thank you for helping and improving Xperia devices!
Alex
1 REPLY 1
AlexandruRai
Contributor
Alex
