Was doing the update today for my Xperia Z once it said completed I removed my phone from the computer now it wont go past the first Sony screen. I have done the 3 button reset and nothing happened. is there a way to do a hard reset from the computer or is there a way to restore to a previous version?
Repeat the update process either
PCC or SUS or Bridge or Flashtool
Don't forget to give Kudos
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
Don't forget the Kudos
Thanks for the help
Anytime
