i use the xperia chinese keyboard
when in phonepad mode to write a txt the problem is trying to scroll up or down in the smiley/symbols box.as soon as you touch the screen to scroll it chooses the symbol/smiley and not let you scroll up or down. also some menus are duplicated in call settings and sound settings but this isnt a problem just maybe an error on the update.
if i have international kbrd in phonepad it works fine when adding a smiley etc.
but using xperia chinese (english settings) it will scroll but whateva u touch to scroll it pastes it on your msg
that's quite odd, I can't recreate the same problem on my Xperia Z, what if you try this
settings > apps > all > xperia keyboard and clear everything
will i still be able to restore the app and settings after i clear ?
and do i do chinese keyboard app and clear ?
yeah, you are not disabling anything just clearing, and yes do the same for the chinese keyboard.
done it and set it the way i like it again but still no joy, it still works fine in the international phonepad settings
that's quite odd, which build number do you have?
settings > about phone
1031A0244
that's the latest, I'm out of suggestions regarding that, sorry
really appreciate you trying mate,
and you learnt me a few xtra things about my sony z
still think its the best phone on the market and i will keep trying the pc companion update service which one day could fix the little glitch it has
CHEERS
