My mic didnt work. Please help
SOLVED
Pablov
1 ACCEPTED SOLUTION
Accepted Solutions
Daniel1
Hi @Pablov, I'm sorry to hear about that. Slightly_frowning_Face
I would recommend you to try the microphone in the diagnostics tool in your device, you can find that by going to: Settings > About phone > Support > Test > Microphone. How does the device react in the test?
If you still are experiencing it after this, I would recommend you to try rebooting your phone in safe mode and see how the device reacts in this mode.
Get back to me with how it went! smile happy
2 REPLIES 2
Daniel1
Pablov
Sony companion fix it. Thanks
