what is the difference between build number 4.0.1.A.0.283 versus 4.0.2.A.0.42? both are android version 2.3.4
SOLVED
Not applicable
i flashed mine coz i like the features of 2.3.4 and the build number is  4.0.1.A.0.28.
can anyone tell me if for example i wanted to repair my phone and get the official update of 2.3.4 is it more stable OS compared the OS version that i used to flash a month ago...? does the build number means something like more stable-4.0.2.A.0.42?
1 ACCEPTED SOLUTION
Accepted Solutions
17 REPLIES 17
always go for the latest firmware, sometimes nothing is changed but few extra/less apps
Not applicable
a follow up question, the build number 4.0.2.A.42 is more latest than the other one? thanks
Not applicable
I think I'm in the same boat. I flashed the 4.0.1 build on to my Neo as per your helpful instructions posted somewhere else. Is there a way of getting rid of 4.0.1 to get 4.0.2 (which I'm assuming is the official UK update)? I tried going back to factory settings and repairing via PC Companion but 4.0.1 doesn't shift!
Not applicable
Also, uliwooly, is there a new clock or timer in 4.0.2, which wasn't there (as had been suggested) in 4.0.1?
Not applicable
i wanna fix this also.... Hope uliwooly can help us.... where are u mate? need help here....
Not applicable
big thanks..... well it seems that i have to flash my phone again and experience the difference between builds... well i will flash if i've got time coz it needs a lot of time to update my files again... nweiz thanks..
if someone can specifically describe between the diffirence between this builds it would be a great help...
anytime, remember to check the other ways to backup your phone, just in case
Not applicable
i do appreciate your help....
